Instrument Cluster
Old May 5, 2021 | 08:16 PM
04disco2va's Avatar
Default Instrument Cluster
Where is the mileage stored. Is it in the cluster or the computer ? I scratched the clear plastic on the front shield installing led’s wondering if I just can replace that piece or I have to purchase the whole cluster. Thanks.
Old May 5, 2021 | 09:36 PM
Best4x4's Avatar
Cluster can be torn down into multiple pieces. If you're talking about the very outer clear part which covers all the gauges = yes you can simply swap it. Mileage is stored in both the BCU and cluster.
Old May 5, 2021 | 09:45 PM
04disco2va's Avatar
Appreciate it Best. Thanks. Good news.
Old May 5, 2021 | 10:08 PM
Best4x4's Avatar
No problem at all
Old May 7, 2021 | 01:54 PM
DiscoJunction's Avatar
My LED odemeter display is totally melted and unreadable. Can I swap that out as well?
2004 G4 edition Discovery 2. (brand new Land Rover owner!)
Old May 7, 2021 | 02:25 PM
Best4x4's Avatar
If you can get a used cluster with lower mileage then all you have to do is SYNC it to the BCU.
Old May 7, 2021 | 04:16 PM
04disco2va's Avatar
so key is getting one with lower mileage so you can sync. Does the iLand software do that ?
Old May 7, 2021 | 06:21 PM
Best4x4's Avatar
Not sure I know the Nanocom does it for sure (haven't used the iLand unit).
If RoverMasterTech chimes in it'll either require a 20.00 scanner or just a battery disconnect for what it's worth
landroverdude
Mar 5, 2020 09:35 AM
Wesley Cantrell
Oct 21, 2017 08:48 AM
Uss
Defender
Aug 17, 2017 07:58 AM
abran
Jun 5, 2016 09:22 PM
Litespeed19
Nov 3, 2010 08:51 AM
