Instrument cluster board replacement
Old Jul 13, 2018 | 09:01 AM
Bradartigue's Avatar
7th Gear
Default Instrument cluster board replacement
Hello, I'm new to the forum and thanks in advance for the help.
I have an 00 Discovery II. The previous owner "solved" the three amigos by opening up the cluster and ripping out the LEDs. I've fixed the actual problem (shuttle valve seals) and would like for these lights to work as designed (because I like things to work as designed, even if annoying at times). Is it possible to replace the circuit board with one from another Disco II? The speedometer is the issue I'm thinking of, that if the mileage doesn't match it will blink or immobilize.
Thanks!
Old Jul 13, 2018 | 10:13 AM
Sixpack577's Avatar
You can solder another led on to the board.
Old Jul 13, 2018 | 11:00 AM
7th Gear
It’s a very tight spot and very small solder points. Have you done it? Advice please
Old Jul 13, 2018 | 11:27 AM
Sixpack577's Avatar
I have soldered on circuit boards before, but have not had the guages out on my D2.
I would get a junkyard cluster, heat the solder on the junkyard board, and remove the led with tweezers.
Then hold it on your board, and use a very small amount of solder to reinstall.
There are various threads here pertaining to getting the odometer not to flash with a different cluster or ecu.
I think that can be done with a Nanocom, but I am not sure, as it's been a while since I've been reading about it, and so far have not had that problem myself.
Old Jul 13, 2018 | 11:31 AM
Best4x4's Avatar
With a T4 you can even disable the flash odometer setting so it will never flash.
Jst4fun
Oct 20, 2017 09:52 AM
Uss
Defender
Aug 17, 2017 07:58 AM
bballjames
Apr 4, 2016 04:34 PM
Litespeed19
Nov 3, 2010 08:51 AM
hilltoppersx
May 1, 2010 07:04 PM
