Instrument Panel
Old Aug 29, 2010 | 10:02 PM
khandrh's Avatar
Default Instrument Panel
Having a rela bad weekenf. Not sure of all these are related. Its started by the AC/Heater Blower not working / now the instruments panel does not light up. I have checked the dimmer switch and it is on high, and the passenger tail light does not work. The brake and reverse work but not the tail. I switched the buld with the other to make sure it was not the bulbs and they are fine. Could all these be related somehow, electrical issue...
I have checked the threads, and I did find that I had water in one of the tails lights. Dumped the water out. Shiuld I wait for it to dry ?. I was thinking of bringing it to the dealer to get an idea of whats going on, since its free and then take it from there.
Help is always greatly appreciated
Old Aug 30, 2010 | 09:59 AM
You need to make sure that the tail light that had water in it is not all corroded, if there is a bad ground or a shorted out contact it could very well be causing all these issues.
Apilky
Aug 5, 2008 05:47 PM
afox04
Apr 28, 2008 10:15 AM
jonnymcd
Mar 24, 2007 01:07 AM
litterlout
Aug 27, 2006 11:16 AM
James Vee
Feb 1, 2006 10:34 AM
