instrument panel warning bulbs replacement
Old Nov 20, 2008 | 05:07 PM
rphotographer's Avatar
Default instrument panel warning bulbs replacement
Hello,
I have a 99 disco series II, I need to replace some of the warning bulbs in my instrument panel.
does the cowling just lift off??
what about the switches located on each side of the cowling??...will I need to unplug them??
and how hard are the bulbs to get to and replace???
thanks
Ralph
www.ralphduke.com
Old Nov 20, 2008 | 06:25 PM
Default RE: instrument panel warning bulbs replacement
This is how you do it on a DI, I think a DII is the same.
Lower the steering wheel all the way, ther are two screws, remove them. Then the cowling just lifts off, the switches come with it.
Old Nov 20, 2008 | 08:20 PM
Willie 00D2's Avatar
Most of them are LEDs rather then normal bulbs. Did they work before? I have heard of people buying rigs with bulbs removed, theyput bulbs in and the dash is lit up like a christmas tree. There is a sticker on the instrument housing that says static sensitive. Most of the lights are inside the housing. There are a few that install from the outside of the housing for instrument backlights.
Willie
Kordian
Mar 18, 2015 06:06 AM
Prometheus
Jan 18, 2011 07:37 AM
yukonridin23
Oct 26, 2009 11:14 PM
CandiMan
Oct 30, 2008 01:39 AM
James Vee
Feb 1, 2006 10:34 AM
