INSTRUMENTS LIGTHS OUT AND LEFT TAIL LITGHS OUT
Old Dec 28, 2005 | 12:30 AM
yogi's Avatar
6th Gear
Default INSTRUMENTS LIGTHS OUT AND LEFT TAIL LITGHS OUT
OK I CHECK THE FUSES AND I REPLACE THE LITGHS SWITCH WITH NO SUCCES I AM STILL IN DARK PLEASE HELP
Old Dec 28, 2005 | 01:23 AM
mikemeyer0's Avatar
Default RE: INSTRUMENTS LIGTHS OUT AND LEFT TAIL LITGHS OUT
20 amp fuse under hood. Also i got my vote that you tried to turn on your fog lamps when it blew.
Old Dec 28, 2005 | 12:01 PM
yogi's Avatar
6th Gear
FUSE NR# ? AND WHAT SUPPLY i TRAY FUSE 14 AND IS OK
Old Dec 28, 2005 | 07:31 PM
05LandRover's Avatar
what year is the disco? sounds like there might be a short somewhere if you replaced the fuse and nothing changed
Old Dec 28, 2005 | 11:03 PM
yogi's Avatar
6th Gear
97 I CHECK THE ALL THE FUSE UNDER THE STERING WHEEL AND ALL ARE OK
Old Jan 5, 2006 | 08:16 PM
Lebowski87's Avatar
Its your light switch mounted on your steering wheels, your int lights shouldnt be working but your break lights should except for the running lights. I dont think it is the dimmer switch but instead the light arm. If you can find one, just get a cig lighter attachment that had the positive and negative wire connectors on the end and wire it directly for the meantime, worked for me.
Old Jan 11, 2006 | 08:31 AM
jack's Avatar
ORIGINAL: Lebowski87
6 Disco.
funny enough i'm having the same problem. All of a sudenthe interior dash lights and front and rear parking lights do not go on. I'll check the fuse under the hood does anyone know which fuse i should check. There are five or six there and I'm not usre which one is it. If that doesn;t work it sounds like i might have to replace the switch on the steering column. Until i find a replacement, can someone tell me how to use the cigarette lighter pigtail to bpass the system? What do i connect the two wires coming from the plug to? I'm dead in the water for night driving now.
By the way, I have a 96 Disco.
Classic74
Mar 15, 2013 08:57 AM
Savannah Buzz
May 9, 2012 01:50 PM
i5mast
Mar 16, 2011 09:38 AM
bowser881
Jan 29, 2009 05:34 PM
Britishmachine
Apr 13, 2008 02:10 PM
