Intake gasket - question about other gaskets
Old Sep 19, 2012 | 04:53 PM
Pwoens's Avatar
Default Intake gasket - question about other gaskets
I was on british atlantic and found an intake/valve cover gasket kit that included a coolant elbow gasket and like 4-5 other gaskets. I have a leaking valve cover gasket for sure but my question is do I need all these other gaskets? I know i'll need the intake gasket too but not sure i need these other 4-5 gaskets??
The complete kit for intake, valve cover, elbow, etc is $119. I can get valve cover gaskets and bolts for $29.95 and the intake for $39.95. So the price difference is quite a bit. I dont want to order all these other gaskets if I dont need them??
Old Sep 19, 2012 | 06:44 PM
jafir's Avatar
I assume you are talking about the upper intake gasket, right? Buy it from rovahfarm or British pacific. It's less than $10.
Old Sep 19, 2012 | 07:11 PM
Better yet try tightening the v/c bolts with an 8mm 12 point socket, they tend to vibrate loose.
Old Sep 19, 2012 | 11:10 PM
Pwoens's Avatar
Hey bud...I did try to tighten them and they are tight. So it's on to replacing the gasket. Just not sure I need all these gaskets?
Old Sep 19, 2012 | 11:31 PM
DiscoRover007's Avatar
You should be able to find the VC gasket by itself on ebay quite cheaply. However if you end up buying a set of gaskets just hang on to the extra ones for a rainy day. But to do the actual job itself does not require anything but the VC gasket. You can replace the upper plenum gasket if you want but many have reused it with no problems.
Old Sep 20, 2012 | 08:50 AM
All you will need are the v/c gaskets, 8 new bolts and a little blue Lock Tite.
You might want to consider replacing your plug wires at the same time if the are the original grey wires, going to an 8 mm silicone wire.
Old Sep 20, 2012 | 10:35 AM
jafir's Avatar
rovahfarm has the v/c gaskets for 6.99 each and the upper intake gasket for $9.65. For less than $10 I'd replace the upper intake gasket just to have piece of mind. It is a metal gasket, and many people reuse them, but I think the deciding factor in reusing it, sometimes, is the $40 that land rover wants for it.
Old Sep 20, 2012 | 10:33 PM
Pwoens's Avatar
well...suppose I should have checked back on replies here before i pulled the trigger . I bought intake gasket at $39.95 and VC gaskets and 8 new bolts for VC. Hoping this is all thats leaking!
Thanks for the input everyone.
jpmiller
Sep 26, 2012 06:32 AM
jkid
Oct 22, 2008 10:14 PM
brw1982
Jul 21, 2008 11:42 AM
