Intake manifold
Old Aug 10, 2018 | 06:36 PM
redwhitekat's Avatar
Default Intake manifold
ok I'm checking my plugs and peeking around because of the 0130 code
can someone confirm something ? On top of manifold you have 4 bolts holding it down kinda of in the middle
now forwards back of manifold at the base I see a Empty hole like a bolt is meant to be there ??
I don't get vacuum there but it's open
can someone confirm what's suppose to be there ?
Old Aug 10, 2018 | 06:46 PM
Best4x4's Avatar
It’s got 4 long 10mm bolts & two short 10mm head bolts holding into place. Front one is dead center on the front lip of the intake & the rear one is dead center on the back just above and in front of the coil pack mounting area.
Old Aug 10, 2018 | 07:02 PM
I'm missing a short 10 mm bolt then.
If water was to get in there would it make its way in ??? There was no vaccun leak
Old Aug 10, 2018 | 09:08 PM
Best4x4's Avatar
I doubt it, I've seen a few V8's missing those bolts with no issues, just make sure the 4 long ones are tight. Should be able to get a new bolt at any good hardware store.
discorona
Feb 21, 2019 10:00 AM
USAroverman
May 31, 2015 05:20 PM
jna97
Feb 21, 2014 09:13 AM
0304Disco
Apr 13, 2012 12:27 PM
roverwoody
Sep 9, 2008 10:12 AM
