Intake Manifold Misc Parts
Old Apr 20, 2017 | 09:11 AM
robert.juric's Avatar
Default Intake Manifold Misc Parts
I was looking at some parts on the intake manifold and I saw some things in the diagram that I don't recall when removing my manifold.
#2 is listed as "Engine Plug, Qty 2 required"
#10 is listed as "Spacer"
#11 is listed as "Blanking Plug"
Also I don't see the little red piece next to #4 in the diagram which helps "bite" into the hard plastic tube? Is that replaceable?
Old Apr 20, 2017 | 09:31 AM
I found the little red part next to #4, its the brake servo vacuum connector: LZN100220L.
Old Apr 20, 2017 | 10:58 AM
Jeff Blake's Avatar
No clue on on the plugs, but the spacer you'll likely find already attached on the lower intake. There are two I believe
Old Apr 20, 2017 | 11:23 AM
BackInA88's Avatar
#10 is the spacer that goes between the heater core supply feed tube mounting bracket and the upper intake plenum, on the stud.
#2 is I believe is a core plug on the back of the upper plenum?
#11 rubber plug over the vacuum port on the upper plenum near #4?
Old Apr 21, 2017 | 08:15 AM
matt3502's Avatar
#11 is the plug that goes over the port in the Plenum if you do not have SAI. If you have SAI, then one of the vacuum hoses running from the small vacuum reservoir above the SAI pump goes into that port.
Jull
Jun 11, 2009 08:12 PM
Street Wolf
13
Apr 21, 2009 03:04 PM
paul1454
Jan 30, 2009 08:43 PM
1994discovery
May 28, 2008 03:28 PM
Brad S1
Jul 4, 2006 06:51 PM
