Intake/valley gasket/pan fitment
Old Jul 15, 2017 | 09:13 AM
04in719's Avatar
Default Intake/valley gasket/pan fitment
Apologies in advance for making new threads on my head gasket project; may or may not prove to be helpful to others (the purpose of this forum as redundant it may be sometimes).
In my other posts I've gone down the head gasket road myself. Really not bad for a shadetree mechanic with some years experience. Pictures and zip lock bags are you friend and I like to set down a tarp and work chronologically from the back to the front to help as well.
With that said I'm getting ready to put in the lower intake, gasket and end gaskets. Like I've done so far I do a quick test fit to make sure I've got the orientation correct and the correct bolts.
Doesn't seem to me that this gasket is a correct fit, it's off just a bit no?
I've also test fitted it to the back side of the manifold and it's off as well unless I deform the gasket to a more "taco" shape.
Is this normal? Perhaps when everything is tightended down it'll be good?
As I see it now the gasket would interfere with intake flow among other things.
Maybe I've just contracted the Rover "paranoia"
Old Jul 15, 2017 | 12:06 PM
Alex_M's Avatar
Are the retainers down tight? I'd loosen them a hair, press down the middle, and then tighten them back down. Thats not correct fit, but should just be an adjustment issue.
Old Jul 15, 2017 | 01:01 PM
04in719's Avatar
I'll give it a 2nd go, thanks Alex_M.
Old Jul 15, 2017 | 01:39 PM
04in719's Avatar
Still not lining up exactly after tightening down end brackets/bolts. Just not comfortable with how much gasket is in the way of flow to heads. It's just a milometer or so but bothers me. Maybe when the intake gets torqued down all will line up???
Old Jul 15, 2017 | 02:31 PM
PalmettoDisco's Avatar
If the bolt holes are clear enough, try partially bolting the intake down, maybe just four bolts, one on each corner. Snug up the bolts, then remove the intake to see if gasket is seated better.
Edit: If bolt hole are not adequately clear, try placing intake, without bolts, and lean on it (apply weight) and see if it seats better. You may have to release the retainers, front and back, first.
Old Jul 16, 2017 | 07:57 AM
BackInA88's Avatar
Don't forget the RTV in the 4 corners where the heads meet the block.
Old Jul 16, 2017 | 04:16 PM
04in719's Avatar
Thanks everyone, I did a few bolts like PalmettoDisco sugested and it all settled in nicely.
BackinA88, thank you. I did the RTV per RAVE.
Old Jul 16, 2017 | 08:34 PM
Thanks for letting us know the outcome. Glad things are moving forward.
Old Aug 20, 2018 | 08:13 AM
CollieRover's Avatar
Thanks for this thread, as I was just about to repost same question. Last Valley pan did not seat very well.
The last gasket I got with my HG kit was deformed to fit in the box. Not a fan of that. The Fel-pro’s come in a box so better shape to start with.
Old Aug 20, 2018 | 07:52 PM
duscarter's Avatar
Where did you buy your gasket kit from? I'm looking at them now.
