Intake/valley gasket/pan fitment
I don’t do negative reviews, so I will just say the Fel-Pro gaskets come in boxes. From intake to plenum to Rocker cover. I highly recommend molded rocker cover gaskets, unless you just Love a challenge that will drop metal ringlets into your valvetrain.
OverRover (08-20-2018)
I use Fel-Pro or Mahle/Victor Reinz for ONLY 1 simple reason...… they WORK RIGHT THE FIRST TIME!!!!!!
Fel-Pro Part #s:
Intake Manifold Gasket Set > MS97186
Intake Plenum Gasket > MS97221
Valve Cover Gaskets > VS50789R
All of these bits are less than $50.00 total at RAuto. Go NUTZ!
I can tell you not to ever use your finger inside a port on the head to try to align the gasket. The water jacket port in the front is a sharp as a razor. Ask me how I know. I dripped a lot of blood all over my valley pan gasket. On top of that I had to finish setting the lower intake manifold while the gasket tack was still workable. I really should have had a couple stitches in my right index finger, but instead I just glued it together with a type of super glue for wound closure. The subcutaneous tissue hurt for a long time after.
The following 2 users liked this post by OverRover:
CollieRover (08-21-2018),
shanechevelle (08-22-2018)
Fel-Pro Part #s:
Fel-Pro Part #s:
I’ve seen the Victor Reinz in a complete set, might go that route.
Also, just for future reference...stitches are for women and children...lol.
Brian.
