Intake/valley gasket/pan fitment
Old Aug 20, 2018 | 09:15 PM
CollieRover's Avatar
Originally Posted by duscarter
Where did you buy your gasket kit from? I'm looking at them now.
I don’t do negative reviews, so I will just say the Fel-Pro gaskets come in boxes. From intake to plenum to Rocker cover. I highly recommend molded rocker cover gaskets, unless you just Love a challenge that will drop metal ringlets into your valvetrain.
Old Aug 20, 2018 | 11:11 PM
OverRover's Avatar
Originally Posted by CollieRover
I don’t do negative reviews, so I will just say the Fel-Pro gaskets come in boxes. From intake to plenum to Rocker cover. I highly recommend molded rocker cover gaskets, unless you just Love a challenge that will drop metal ringlets into your drivetrain.
+1
I use Fel-Pro or Mahle/Victor Reinz for ONLY 1 simple reason...… they WORK RIGHT THE FIRST TIME!!!!!!
Fel-Pro Part #s:
Intake Manifold Gasket Set > MS97186
Intake Plenum Gasket > MS97221
Valve Cover Gaskets > VS50789R
All of these bits are less than $50.00 total at RAuto. Go NUTZ!
Old Aug 20, 2018 | 11:27 PM
Colorado David's Avatar
I can tell you not to ever use your finger inside a port on the head to try to align the gasket. The water jacket port in the front is a sharp as a razor. Ask me how I know. I dripped a lot of blood all over my valley pan gasket. On top of that I had to finish setting the lower intake manifold while the gasket tack was still workable. I really should have had a couple stitches in my right index finger, but instead I just glued it together with a type of super glue for wound closure. The subcutaneous tissue hurt for a long time after.
Old Aug 21, 2018 | 08:06 AM
I would do this.
Old Aug 21, 2018 | 08:48 AM
OverRover's Avatar
That's why The Mandage was invented
Old Aug 21, 2018 | 12:30 PM
Let's see someone do a rag and zip tie on their dominant hand by themselves. Ha.
Old Aug 21, 2018 | 03:19 PM
OverRover's Avatar
But that's why it's called a " MANDAGE " ….
Old Aug 21, 2018 | 04:22 PM
duscarter's Avatar
+1
Fel-Pro Part #s:
I would buy Fel-Pro if it was a complete set, I don’t want to start and be missing an O ring.
I’ve seen the Victor Reinz in a complete set, might go that route.
Old Aug 22, 2018 | 03:43 AM
The Deputy's Avatar
You'll get there, if you keep working on this rover long enough. Most, if not all, good mechanics are ambidextrous.
Also, just for future reference...stitches are for women and children...lol.
​​​​​​​ Brian.
Old Aug 31, 2018 | 05:05 PM
Got this in today. I bolted it down twice, removedclimbed on top of it pushed it, and I hope it sat well, and the manipulating dosn’t Affect the RTV at the corners.
Mused the permatex gasket prep, I’m not sure it got in perfectly, but better than last time.
Savannah Buzz
Jul 24, 2013 09:49 PM
Savannah Buzz
Jun 23, 2013 03:46 PM
MrFlea1
Dec 5, 2011 08:17 PM
terryderlo
Aug 8, 2010 06:16 AM
jasonabarrett
Jun 26, 2010 09:08 AM
