Intake Whistle/Whine
Old May 10, 2013 | 12:36 PM
Bryan H's Avatar
Default Intake Whistle/Whine
I recently installed a new longblock in a disco I purchased with a blown motor. The engine runs great. However, when accelerating from a stop or cruising at about 25% throttle, I get a very high pitched whistle/whine. If I'm driving at about 45 mph on flat ground and applying just enough throttle to maintain speed, the whine is quite audible. But if I let off the throttle, it immediately goes away.
I've replaced the air filter box and intake elbow b/c they were both cracked, but that didn't stop the whine. Is it possible that I could have an upper and/or lower intake air leak that would whine like that? My idle is also a bit rough, so that also makes me wonder if I have some sort of leak that would contribute to the rough idle.
Thanks in advance,
Bryan
Old May 10, 2013 | 01:54 PM
coors's Avatar
Thanks in advance,
Bryan
the rough idle you mentioned leads me to believe it's a vacuum leak. try to spray carb cleaner around the manifold seals, see if you can get the intake to suck it in. if there is a leak it should suck the carb cleaner and start to sputter.
I'm not sure of another way to check for vacuum short of in-lining a gauge.
Old May 10, 2013 | 02:25 PM
Bryan H's Avatar
I was wondering if you could do something like that. Will it sputter or increase rpm?
Old May 11, 2013 | 11:24 AM
SuperSport's Avatar
Depending on your spray, it should increase RPM. But, either way, you will notice a difference if it enters.
Old May 11, 2013 | 12:37 PM
un-lit propane torch is another source....
sometimes listening to taget areas thru a short piece of hose works.
Old May 11, 2013 | 02:54 PM
coors's Avatar
I thought it would make the engine sputter. Regardless, SuperSport is correct you will know the difference once you get the spray to that sweet spot.
Old Oct 6, 2013 | 08:03 PM
03Discovery4EUX248's Avatar
I have a 2003 discovery SE7, I have the same issue, the vehicle whistles when under acceleration. It does not whistle when I lift off the accelerator. Please tell me if you ever resolved your issue and if so what was the result? Thx
Old Feb 5, 2015 | 08:21 PM
redrover75's Avatar
Me too. Trying to sort out a whine.
lilherc
Nov 30, 2013 11:09 AM
focusontheworld
Nov 13, 2007 08:49 PM
ghinesley
Aug 6, 2007 01:48 PM
xadamx
Mar 2, 2007 04:35 PM
LordOphidian
Jan 31, 2007 01:42 PM
