Interesting HD RotoFlex:
Old Nov 19, 2020 | 09:00 PM
Best4x4's Avatar
Default Interesting HD RotoFlex:
While looking around for the 35mm thick RotoFlex replacement I came across this interesting looking replacement for the BMW's. It's a HD poly bushing unit vs rubber in a 6061 Aluminum body.
Old Nov 19, 2020 | 09:44 PM
Sandman614's Avatar
Yes, interesting. Maybe one day I'll give it a shot, plus the red has to make it faster.
Old Nov 20, 2020 | 02:08 AM
11chuck's Avatar
I use one like this on my GTO, believe from Revshift. Have kind of a custom driveshaft setup goin on. The more you can stiffen the driveline up the better in my opinion.
I replaced the one on my rover with just a stock style replacement type a while back so don't really have need for something like this. I remember comparing it with a spare GTO one I had laying aeound at the time and I believe there were some differences in spacing though... can't remember. I do think the GTO one can be cross referenced to a BMW part number but not so sure about rover, especially considering the differences I noticed when comparing. But who knows, might be able to find one. Maybe they were the same and I'm just not remembering right.
Old Nov 20, 2020 | 03:04 AM
JUKE179r's Avatar
Cool find @Best4x4 ! What is the cost or got a link to it?
Old Nov 20, 2020 | 07:47 AM
ahab's Avatar
Also available in green ;-P , and, if you buy from FCP it's guaranteed for life. The colors my be related to the durometer of the urethane, or maybe simply because racecar. That said, as with any poly bushing, NVH goes up and you lose the dampening properties of the rubber. In my opinion, if you're trying to improve launch and get a more direct connection with the ground then these fit the bill however I think that especially for low speed offroading, the flex of the OE design is more desirable. I'm not saying these are a bad idea, but while you may be reducing the chance of failure by using the aluminum and urethane version, you're also transferring that stress to a different part of the driveline.
https://www.fcpeuro.com/products/bmw...vshift-pfx9612
Except for the rounder shape of the LR version, the BMW guibo is otherwise dimensionally the same as far as thickness and bolt circle so the one in the link above will fit the Disco.
Old Nov 20, 2020 | 08:05 AM
Best4x4's Avatar
Yeah I'm not sure being stiff for off road would help, but I just wanted to post it.
Old Nov 20, 2020 | 09:37 AM
Sandman614's Avatar
I like FCP, Plus $10 off with coupon code
boston4
Jul 28, 2021 03:16 PM
Fanuvkorn
Aug 24, 2020 08:24 AM
elboy0712
Dec 10, 2017 05:40 PM
Jay5oh
Jun 5, 2014 04:54 PM
Disco2Guy
Jul 19, 2008 02:23 AM
