interior ac fan
Old Aug 18, 2012 | 03:34 PM
chefcarl's Avatar
3rd Gear
Default interior ac fan
my ac fan has stopped blowing on my 2003 discovery. It seems to start blowing whenever it likes. sometimes if i turn the engine off and back on it will blow. with out the fan i dont get cool air blowing thru my vents. what seems to be the problem and how can i fix?
Old Aug 18, 2012 | 03:37 PM
br0keit's Avatar
Does it always blow on full speed? Does it make a lot of noise when it does blow?
Old Aug 18, 2012 | 03:39 PM
chefcarl's Avatar
3rd Gear
when it does come on it works like it should.
Old Aug 19, 2012 | 08:46 AM
wilson96rr's Avatar
Well, it is either a loose wire/connector, a bad fan motor, bad control panel, or a bad interior fuse box. Only way to tell for sure is to get a test light and start testing. Start with testing for power at the motor. My guess is the fuse box, but it is just a guess based on failure rate.
Old Aug 19, 2012 | 09:50 AM
chefcarl's Avatar
3rd Gear
Where are these parts located on the vehicle.....
Old Aug 19, 2012 | 10:56 AM
chef - you'll want to download the RAVE shop manual and peek through it. I would not know how to swap the circulating blower out in a double stack convection oven without a book either.
usnavylt
LR4
May 1, 2015 03:40 AM
rover1978
Sep 26, 2009 09:05 PM
jmt
Jan 14, 2008 05:01 PM
igriego
Apr 17, 2007 08:19 PM
