Interior Dead
Old 06-01-2010 | 11:22 AM
Runner_K's Avatar
5th Gear
Default Interior Dead
To sum it up the radio, dome lights, changer, remote locks are all dead. Everything else works. All went dead at once. Help!
Old 06-01-2010 | 11:28 AM
We need to know the year.
Old 06-01-2010 | 11:29 AM
03discoman's Avatar
check the battery first for a charge and that the cables are on good and tight...if there is corrosion ...clean it up..
then check fuses...under the hood and in the truck....unplug all accessories like car chargers and ipod chargers.....they might be shorting the system.
Old 06-01-2010 | 11:34 AM
Runner_K's Avatar
5th Gear
Its a 2003 SE
Old 06-01-2010 | 11:44 AM
Check all fuses, including the ones under the hood.
Do your wipers work? How about the rear defroster? Rear wiper? Windshield washers? Cruise? High beams? Turn signals?
Old 06-01-2010 | 11:55 AM
Runner_K's Avatar
5th Gear
They all work
Old 06-01-2010 | 12:03 PM
This sounds like a fuse problem.
Either the fuse is blown or that part of the fuse block is dead.
Old 06-01-2010 | 12:23 PM
Runner_K's Avatar
5th Gear
All the fuses are good
Old 06-01-2010 | 12:27 PM
Check for power at the fuse.
So remove the fuse and using a voltmeter make sure that the fuse is getting power.
Old 06-01-2010 | 05:15 PM
Danny Lee 97 Disco's Avatar
Did your CD Changer get wet? If you got wet carpets (leak) you may have a short underneath the carpets.
LR was terrible about running the wire harnesses in some bad areas and there are splices internal to the wire bundle that are not well insulated.
I have removed all the carpets from my 97 Disco I, rewrapped and rerouted wire bundles, removed a dead CD Deck from under the passengers seat and a few other things. Still have some rust and resealing issue to deal with.
There are several areas where water can get in, especially under the carpets.
Quick Reply: Interior Dead
