interior lights
Old Nov 8, 2004 | 01:18 PM
bigharp's Avatar
Default interior lights
I recently bought an 01 Discovery. I have a problem, the interior lights wont come on. I checked the bulbs they all look good. I checked the fuses that control the interior lights, none have blown. The vanity mirror lights work and the glove box light work but none of the other interior lights work. Can anyone help?
Old Nov 8, 2004 | 06:12 PM
Takeo's Avatar
Default RE: interior lights
Hi !
Did you check the door switch ? i.e. the switch somewhere in the door frame, it switches the light on when you open the door; these tend to get dirty contact surfaces...
Also, is there not a switching position somewhere so that the interior light can be switched off ? Check owners manual for this.
Regards,
Takeo
http://www.landroverclub.net
Old Nov 9, 2004 | 01:37 PM
bigharp's Avatar
I will try that stuff thanks. I was talking to a guy who works at a dealership. He told me something about a dome relay. He spoke like it might be a fuse for this under the hood. Have you ever of this and do you know the fuse number (I misplaced my owners manual).
Old Sep 27, 2009 | 11:31 PM
ngv151515's Avatar
i have the same problem... i need my dome lights anyone found this problem?
Old Sep 28, 2009 | 08:55 AM
What have you checked so far?
Old Sep 28, 2009 | 09:25 AM
ngv151515's Avatar
checked all bulbs, checked power at conector but didnt check for ground cuz already didnt have power, all fuses under steering wheel
Old Sep 28, 2009 | 09:23 PM
ngv151515's Avatar
ok i just spend 2 hours trying to fix this.
front dome light: ON position left side bulb has ground flickering and rt side has just ground. DOOR position has 12volts left and right side. OFF position has 12 volts left and right side. What the ...
Old Sep 29, 2009 | 07:58 AM
ngv151515's Avatar
also when i turn front dome light ON the light ring where the key goes lights up but on the other pos. turns off
Old Sep 29, 2009 | 03:57 PM
ngv151515's Avatar
finally found the problem!!!!! (after 2 hours)
a header was rusted under the a/c blower C0289 (K109) color green now i will have to solider 6 wire pins and get a new header
usnavylt
LR4
May 1, 2015 03:40 AM
outdoor7or24
Sep 6, 2012 10:32 PM
mignum
Dec 14, 2009 07:34 PM
DPR81
Feb 3, 2009 05:13 AM
taylorbob1
Mar 21, 2006 12:53 PM
