Interior lights not fading
Old Dec 27, 2015 | 08:35 PM
Redduc's Avatar
Default Interior lights not fading
They all work when in the "on" position, but no longer fade when the doors close. Any ideas?
Old Dec 27, 2015 | 09:13 PM
number9's Avatar
The courtesy lamps operate at full brightness when they are first switched on. The BCU then gradually dims the lamps
(fade-out) before completely switching them off. Fade-out occurs over a period of two seconds following the logical
control signal to turn off the lights.
Any recent mx done?
You might try disconnecting the battery for a complete power down reset of the logic. I've seen many problems cured by doing so.
Old Dec 27, 2015 | 09:29 PM
Redduc's Avatar
No recent service. I'll try disconecting the battery tomorrow.
Old Dec 28, 2015 | 07:09 PM
RegT's Avatar
does the horn go off when you lock the doors with the remote? I had similar issue and when I locked it the horn would go off, turns out that my rear door wasn't closing all the way.
Old Dec 28, 2015 | 07:13 PM
Redduc's Avatar
Thanks for the replies. It fixed itself while I was sleeping. My passenger side window did the same thing.
sorbet35
Feb 8, 2015 03:06 AM
wrongway1
Dec 1, 2012 08:23 PM
Chris-bob
Apr 11, 2012 08:13 PM
mignum
Dec 14, 2009 07:34 PM
Rover601
Jan 28, 2009 07:39 AM
