Radio Display Fading
Old Jan 26, 2009 | 08:53 PM
Rover601's Avatar
3rd Gear
Default Radio Display Fading
Guys,
I have a 2002 Disco II that the radio display keeps fading on. What I mean is that when the radio is first turned on you can see what station it is on. Then it just kind of fades to all green. Like any man I tap the top of the dash board and it comes on only to fade to green again. Any tips?
Thanks guys.
Larry
Old Jan 26, 2009 | 08:58 PM
Default RE: Radio Display Fading
Sounds like you need a new stereo.
www.roverlandparts.com
Or a aftermarket deck from BestBuy.
Old Jan 26, 2009 | 11:18 PM
hazletbassist89's Avatar
Any possibility it's the interior light dimmer switch? Mine got dirty a few months ago and started making the lights on the dash act up. I cleaned it out and problem solved.
Old Jan 26, 2009 | 11:54 PM
lrd2's Avatar
let me know if you are looking to replace the radio i have my factory radio just sitting in my job ill sell it to you
Old Jan 27, 2009 | 08:28 AM
unimoged's Avatar
If you have a spare radio, you can exchange the display / control buttons circuit board. It sits behind the dark grey / black (04) front face.
It is much easier to replace the whole radio.
OE LR radios are relatively cheap. You can find them on EBAY for $40. Some are priced as high as $200.
2000 through 2004 radios (AM/FM/CAS/CD Control) are all the same (excluding NAV). It is a a myth that 2003 and 2004 are different. It is not correct, they all fit.
Old Jan 27, 2009 | 07:23 PM
Rover601's Avatar
3rd Gear
Can you give me a brief description of how to get that front face out? I sure appreciate it!
Thanks,
Larry
Old Jan 27, 2009 | 07:39 PM
unimoged's Avatar
Larry, you need special tools to slide in the two slots on the upper rim of the radio face, to depress the locking latches, so you can slide the radio out. I made my own tools, basically two flat blades that are 4 inches long that have the width of the slots in the radio.
After the radio is pulled out, (Make sure you know the code if it is programmed into the radio) before you disconnect the three plugs in the back.
Now that you have the radio out, look at the sides and you will see two small Phillips head screws that hold the plastic face to the radio body. remove them then gently pry the edge up and out and you will have the front plastic face off. Below it, you will find the display and control buttons circuit board.
Personally, I would put a used radio in it and be done with it.
Old Jan 27, 2009 | 08:52 PM
Rover Curious's Avatar
As a matter of fact, the radio in the '03-'04's is different. As discussed on DWeb, the '03-'04 does not have weather band in the radio electronics. Earlier D2's do. Other than that, they are the same fitment and everything.
Old Jan 28, 2009 | 07:39 AM
unimoged's Avatar
Just replaced the OE radio (W/O nav) in my 04 with a used unit that came out of a 01/02. It works fine and it operates my CD changer.
sorbet35
Feb 8, 2015 03:06 AM
wrongway1
Dec 1, 2012 08:23 PM
Chris-bob
Apr 11, 2012 08:13 PM
Pacifica
Aug 21, 2010 09:49 AM
blip6162
Apr 15, 2010 06:39 AM
