Intermittent 3 Amigos
Old Sep 28, 2010 | 08:55 AM
matt3502's Avatar
Default Intermittent 3 Amigos
Always wanted a LR now I have (04 Disco II 58k) one. I have the three amigos every once in a while. They seem to occur when the weather is very warm 75+. IF i shut the engine off they go away. I have read a number of postings, and see a number of different answers. Do any of the experts know if high temps affect the 3 amigos?
Have not bought an ABS amigo yet. Does anyone know of an indie LR mech in lower Fairfield county CT or a forum memeber in the area who will rent theirs?
Old Sep 28, 2010 | 10:22 AM
hilltoppersx's Avatar
where in fairfield are you? im in Harrison over the border i have one if you want to meet up.
Old Sep 28, 2010 | 02:12 PM
matt3502's Avatar
I am in Ridgefield CT
Old Sep 28, 2010 | 02:46 PM
do you work any further south? in Stamford or Norwalk?
Old Sep 29, 2010 | 08:09 AM
matt3502's Avatar
I work in NYC but can get to where you are without a problem
Old Sep 29, 2010 | 08:30 AM
Are your front wheels all black from brake dust, do your brakes squeak and how long has it been since you did a complete brake fluid flush?
Old Sep 30, 2010 | 11:20 AM
matt3502's Avatar
The front wheels are not black at all. The brakes do not squeak. I have had the car since July and have not done a flush.
Old Sep 30, 2010 | 09:14 PM
oysterhead's Avatar
I guess shuttle valve. Get the codes scanned.
Old Sep 30, 2010 | 11:19 PM
range_time's Avatar
if it resets with the ignition i am 99% sure its the shuttle valve/modulator problem. If you throw a code from a wheel sensor, again I'm 99% sure you have to have your coded reset with a scan gauge. The fact it comes and goes makes it sound like a shuttle valve/modulator issues.
Now i had a the full set of problems when i purchased the Rover, A dry joint in the modulator, a failed shuttle valve and bad front wheel sensor, so i ended up doing all the fixes one after another... then the other front sensor went and i drove it for 7 months and just this week got around to replacing it.
Worth doing. love the no yellow lights look!
Dave
Old Oct 1, 2010 | 07:10 AM
matt3502's Avatar
is the shuttle valve/ modulator a Major repair cost wise?
