Intermittent 3 Amigos
While I'm at it, I may as well post about this problem, too.
I get the tres amigos intermittently. Many times, after starting, everything is fine. Eventually (it seems), I'll get the not so assuring ding and the 3 amigos lights will light up. Sometimes a restart fixes it (only to return eventually), sometimes it doesn't.
I know some of the causes of the 3 amigos but all of the things I know of are NOT intermittent failures. Anyone got any ideas on what I should look at? I'd like to (eventually) fix this.
Thanks.
Thanks.
I've tried that but not getting any codes??? Unless it doesn't store those codes as I haven't been able to check when I actually have the 3 amigos (they are fast and wilely...).
Go here, you can see how to remove the shuttle valve and do "Option B" fix to your new one before installing it. Don't remove the whole ABS unit, just unbolt it from the vehicle and hoist it up enough to get to those three little allenhead screws underneath that hold the shuttle valve in place.
ABS Mod - LAND ROVER CLUB V.I.
Idea on how to hoist the ABS unit up to allow you to remove the shuttle valve from underneath-
New shuttle valve with the "Option B" fix done before installing-
It's easier than changing oil.
I really appreciate your help.
