Intermittent misfires after head gaskets
I did the head gaskets and since have experienced intermittent misfires. When I had everything torn down, I changed the plug wires since it is such a pain to do them. Today I was driving and kaBOOM! My fan blew up and messed up the fan shrouds and the air filter box and damaged the serpentine belt. Peripheral damage from the exploding fan/fan shroud was one hose blown off the thermostat. I've ordered the serpentine belt and fan and for precaution I've ordered a new thermostat. I was able to put stuff back together enough to get it home (just a few blocks and only drove after it was dead cold.) It does not maintain idle. Any advice is appreciated. I've contacted Paul and Will to see about fan shrouds and air filter box.
When the fan destroyed the air box, it may have allowed anti-freeze to come in contact with your MAF sensor (mounted in air intake tube)...causing it to go bad. Are you getting any codes...or check engine light?
And, l'm assuming we're talking about two separate issues here, misfires were happening before fan exploded...and bad idle was after. If you had misfires before, get a code reader and see what cylinder is giving you issues. Could be something as simple as a broken porcelain on spark plug.
Did a tune up on a customers car one time, mutiple/random misfires, running like crud, etc...and had just been "tuned up" by her son a few months ago...so "everything should be okay there" (as she put it). Well, after removing all eight plugs...it had four with broken porcelains. It doesn't take much effort to break a plug.
Brian.
Brian.
Still leaning towards MAF on idling issue...especially...if you found anti-freeze air box or intake tube.
Brian.
