Intermittent oil light at idle
#21
Yes just seing what’s out there. Long shot but if I can find a motor that’s aftermarket it would be ideal
that disco in the ad was my 04 it had a brand new ab engine until my wife wrote off the truck
whoever got that motor from the scrappers scored huge
do you know a good landrover shop in these areas.
#26
Funny you say that. When I changed the oil I didn’t fill the filter all the way like I normally do because I find when I do some Spills out when I screw it in
so this time I just put a bit in
the oil light usually comes on for about 2 seconds normally after I do the oil change
this time it stayed on for about 3 seconds longer
I had a weird feeling about it
#27
#28
Only 88000 miles
everything was perfect before this happen
that’s the upsetting part
maintenance operating temps were all good. How does this happen
#30
That’s for sure however after reading a lot of posts from this forum and others going back a few years
with this problem spent money replacing the oil pump to have the same symptoms
from readibg in most cases it’s not the pump
