Is this an issue?
Old Jul 9, 2023 | 01:05 PM
tanman1234's Avatar
Default Is this an issue?
Letting my engine cool down after hour drive — then change my oil. Is this a bad sign? Oil seems like it’s seeping out of the engine block? Any advice would help. Thanks
Old Jul 9, 2023 | 01:10 PM
Xanthro's Avatar
Have you done the PCV mod?
The OE PCV is almost always clogged, and pressure builds up and oil leaks out.
The mod is on a sticky, and ever D2 should have this done. It is a remarkable improvement.
Old Jul 9, 2023 | 01:13 PM
disco96sd's Avatar
Looks like the valve cover gaskets are leaking - that is an easy job you can tackle
Old Jul 11, 2023 | 01:36 PM
tanman1234's Avatar
Nope! just saw so I guess i’ll be doing this during the winter
Old Jul 11, 2023 | 01:37 PM
tanman1234's Avatar
exactly what I was thinking sounds - annoying job
Old Jul 11, 2023 | 06:35 PM
Harvlr's Avatar
The PCV mod doesn’t take very long to do. Do it before you do the valve covers. If I had a leak like the amount that I see in the photo, I wouldn’t worry about it very much. You can try snugging up the outboard valve cover bolts without taking anything apart. IIRC it’s a 5/16 12 point socket. You need some disassembly to get at the inboard bolts.
mdgs
Oct 11, 2022 04:54 PM
hartfja
Jul 8, 2022 12:05 PM
Brandon318
Aug 1, 2021 09:45 AM
Landy-04
May 3, 2019 07:18 PM
sayeedA
Feb 19, 2017 03:04 PM
