It's Been a Bad Day
Old Feb 14, 2010 | 07:52 AM
ccvalentino's Avatar
Default Transmission?
Is there a reasonable way to check and see if the transmission is trashed or not?
Note: In Park the Discovery rolls.
Old Feb 14, 2010 | 08:15 AM
lipadj46's Avatar
Inspect it for cracks. If you don't see any put some dye in some ATF and fill it up see where it leaks out. If you have cracks in the housing it is finished. Well someone here I recall had luck JB Welding their case but don't count on that.
Old Feb 14, 2010 | 08:30 AM
Yes a visual inspection is the only way to know for sure.
Since all the fluid drained out it either busted a trans cooler line (if your lucky) or it punched a hole in the side of the trans housing.
If it did the latter you will need a new transmission.
www.roverlandparts.com
www.autosportsunlimited.com
Also check e-bay and Craig's list.
Old Feb 14, 2010 | 08:39 AM
lipadj46's Avatar
In the picture I see a hunk out of the transmission housing but the fluid looks like it is coming from the cooler lines maybe you will get lucky. Before I knew better I drove around for maybe 500 miles with a rattly, shaking front u-joint. I was lucky that thing held.
Old Feb 14, 2010 | 12:44 PM
okdiscoguy's Avatar
As stated, see where it is leaking, it will roll in park with no front shaft. Use the parking brake to keep it from rolling.
Old Feb 14, 2010 | 01:47 PM
Default New Pictures from Underneath
Ok,
Crawled underneath and took some new pictures.
It is leaking fluid from what appears to be a seal around the bolt closest to what looks like the transfer case (?).
Thoughts are appreciated.
Chris
Attached Thumbnails It's Been a Bad Day-im000742.jpg   It's Been a Bad Day-im000743.jpg   It's Been a Bad Day-im000744.jpg   It's Been a Bad Day-im000745.jpg
Old Feb 14, 2010 | 02:17 PM
lipadj46's Avatar
Those pictures show damage to the the transmission pan. I would check the actual bell housing where the chunk is missing for cracks. You should be able to salvage it if it is just the pan.
Old Feb 14, 2010 | 02:46 PM
Default Thanks...New Pictures
Thanks,
I took a few more pictures and inspected the bell housing. Looks as if (to the naked eye) there are no visible cracks and the area where the chunk is missing is bone dry.
Chris
Attached Thumbnails It's Been a Bad Day-im000746.jpg   It's Been a Bad Day-im000747.jpg   It's Been a Bad Day-im000748.jpg
Old Feb 14, 2010 | 06:29 PM
Looks to my like you got lucky and all you will need is a new front driveshaft and some trans cooler lines.
And your Y-pipe.
Old Feb 15, 2010 | 12:12 AM
AK Rover's Avatar
It appears you got very lucky. Since the u-joint on the driveshaft side let go instead of at the transfer case it wasn't able to do much damage. Compared to what it could have done anyway. The bell housing is no big deal, nothing is going to leak out of there.
Like Spike said, new driveshaft, y-pipe and oil cooler lines you'll be back on the road.
