its got the shakes
Old May 23, 2009 | 03:54 PM
sadystikal1's Avatar
Default its got the shakes
so i have a 2002 disco and it idles fine but when i go in r or d i jerks, any thoughts i hope none of them involve tranny, but could low tranny fluid cause this?
Old May 23, 2009 | 06:54 PM
Default update
so now it doesnt do it, fluid is good but i can hear the tranny like clunk in gear.
Old May 24, 2009 | 08:56 AM
Have you ever had the front drive shaft rebuilt, if not sure crawl under and see how many grease fitting you have on the front drive shaft.
In the mean time, don't drive the truck.
By the way, how many miles on it and how often do you grease the front drive shafts?
Old May 26, 2009 | 06:19 AM
Default drive shaft
put in a custom grease fitted drive shaft after the first one snapped and cracked the tranny housing like 2 years ago and i havent greased it since, oops, will be doing that this afternoon. i know i know. it has around 120K miles.
Old May 26, 2009 | 09:39 AM
Since they have not been greased in 2 years you will most likly need a new driveshaft again.
Old May 26, 2009 | 10:11 AM
They are supposed to be greased tw1c a year or every other oil change to be safe.
Old May 26, 2009 | 11:06 AM
so even just in and out of a parking spot i noticed it, but when i waited an hour it didnt do it again. would it still be the drive shaft and not the tranny? or yet the transfer case?
Old May 26, 2009 | 11:37 AM
You need to check all over your driveline fluids to make sure that theya re full.
Also check your tire pressure, if one or more tires are low it can cause stress on the driveline.
Old May 26, 2009 | 11:42 AM
Check the rear roto flex wheel and make sure it is not cracked, it is between the rear drive shaft and the differental.
Old May 26, 2009 | 12:01 PM
i will but it will be a little later till i can respond, thank you guys for your help thus far.
