Jack stand location for rear axle swap?
Old 10-05-2020, 07:41 PM
Fastercat's Avatar
Default Jack stand location for rear axle swap?
Are our trucks front heavy enough to put the jack stands by the trailing arm mounts?
I started putting mine at the back by hitch to frame mounts. I need to really block them up to allow enough height to get the axle in the air. I’m not too sure I like doing that.
Old 10-06-2020, 03:04 AM
The Deputy's Avatar
Received 1,278 Likes on 897 Posts
Seeing that the frames on these things, up here, have frames with the strength of tissue paper...l'd locate jack stands in front of rear axle, just ahead of trailing arm frame mount. AND, leave a 3 ton floor jack under rear crossmember or transfer case.
Old 10-06-2020, 10:11 AM
Alex_M's Avatar
I always set mine right under the radius arms mount. Any further forward/rearward and you get to heavy on the end. Tippy.
Mskembo
08-25-2017 03:55 PM
Tadpole
06-06-2015 01:38 AM
LRlax11
04-23-2015 11:42 AM
tnixon44
04-29-2014 01:23 PM
lipadj46
08-16-2009 07:48 AM
Quick Reply: Jack stand location for rear axle swap?
