Jacked in the rear? :( 2"lift
![](https://cimg5.ibsrv.net/gimg/landroverforums.com-vbulletin/322x504/ztfp_cbad9bdb0d47cce69e896984f39743a6baa8ded1.png)
![](https://cimg5.ibsrv.net/gimg/landroverforums.com-vbulletin/500x500/ztf_962d114c5542e245353a3ce57483d14bcc000584.jpg)
" Will remove a rear spring this morning and measure and look for part number. UGH! "
You DON'T need to remove the spring to see the part number. The number is just painted on the OUTSIDE of the spring. Just remove a wheel and you will see the number IF it's there. For example (not your part number), the pic
![What He Said ^^^](https://landroverforums.com/forum/images/smilies/pointup2.png)
And for the record, there is no way in hell those are the correct springs. But will the springs "settle" with weight/time... YES.
You can also expect the paint to chip off fast, and they will also RUST like mad because they are TERRAFirma garbage. Good Luck!
>> FIRST pic is TF023V PS
![Frown](https://landroverforums.com/forum/images/smilies/udbMv2o.png)
Greg Vasileff (11-28-2017)
