Jacked in the rear? :( 2"lift
How many other D2s here do you see with a 2" lift that look like that?
None that I've ever seen.
D2s sit level stock. The 4 springs are the same heigth.
Were the 4 Terrafirma springs the same height??
If so, how about the rubber spacers/seats?
" Will remove a rear spring this morning and measure and look for part number. UGH! "
You DON'T need to remove the spring to see the part number. The number is just painted on the OUTSIDE of the spring. Just remove a wheel and you will see the number IF it's there. For example (not your part number), the pic
is how the TF number stamp looks. In your case something like REAR: TF023V /// FRONT: TF042And for the record, there is no way in hell those are the correct springs. But will the springs "settle" with weight/time... YES.
You can also expect the paint to chip off fast, and they will also RUST like mad because they are TERRAFirma garbage. Good Luck!
>> FIRST pic is TF023V PS
Measure from hub center to fender flare. Rear should be 19" +/- .5"; front should be 19.5" +/- .5"
That's factory spec, so add two inches to that for where you should be sitting.
