jaimelu
Old Nov 21, 2016 | 06:29 PM
JAIMELU's Avatar
Angry jaimelu
My Disco ll 4.0 petrol I have 3 lites on thats stay on
abs, TC and brakes, I found a defective ABS sensor in a rear wheel, was replaced
the lites wen out for a couple of seconds when I first dorve it. they came on again
What could it be .I inquired a WABCO switch module defective, came along the scanner say nothing. What can I do?
thanks for ther help
jaimelu.
Old Dec 24, 2016 | 03:25 AM
Luckyjayb's Avatar
Check the forum for discovery 2 and there is a "sticky" about getting rid of it. There are a vast amount of variable that can cause the "3 amigos" as they are called to appear. It could be a shuttle valve, bad brakes, moisture on the wheel sensors, a bad cable on one of them, air in the brake system, and the list will go on and on. A lot of us use the bypass mode on the write up (option b) and it will clear them and still give you complete functioning of the abs, hill descent, etc. hope this helps. If it doesn't message me and I'll send you a link to it. If all else fails, google discovery 2 3 amigos fix
JAIMELU
Nov 6, 2016 01:42 PM
