The best junk yard day ever!
Old Aug 30, 2011 | 10:01 PM
Dodger's Avatar
Default The best junk yard day ever!
So I took a trip to my local pick-a-part. Behold, a 1995 Disco just like mine, only with jump seats. One was torn, but the other was perfect, so I removed it and all the brackets. Took it to the counter to find out that it was only $19 dollars. So I went back in and got all the sensors, injectors, pressure regulator and the distributor from the engine. Now I have some spare parts! Today I modified a brush guard from a F150 to fit my Disco. It came out great (or at least I think it did). Pics are in my gallery. I am thinking about heading back for the tranny and transfer case. (they will not sell the engine!)
Dodger
Old Aug 30, 2011 | 10:15 PM
A bad day at the junk yard beats a good day at work....
Should have got the alternator, fan clutch if good, radiator (?), electric seat switches (if so equipped). I used a front passenger seat to replace my ripped up driver's seat, bolts right in and cables plug in. Lumbar support **** clears the door post. The pull-a-parts around Atlanta have on-line inventory, and you can even get an email or text message when a vehicle of interest comes on the lot.
And when people complain about a web site or email address, just tell them they are lucky it is not:
universityoftennesseehomeofthevolunteersalumniasso ciationincorporated.org
Old Aug 30, 2011 | 10:22 PM
Dodger's Avatar
The alt. was an aftermarket, and rusted (the hood was removed already). Mine is cloth manual seats, so all that gee-wiz power stuff does not apply. I will most certainly head back for the radiator. My next quest is to figure out what manual window regulator will fit in my Disco, cause I hate power options.
Old Aug 31, 2011 | 01:05 AM
Chris-bob's Avatar
Sweet score!
Old Aug 31, 2011 | 04:17 AM
Starter? Steering box? PS pump? ECU? On the rad, take some clean rubber hose, and use it to blow air thru the oil cooler side when you disconnect the oil lines. I pulled one, flushed it out, installed it, cranked truck, checking for leaks, all good.... then saw that oil light was still on! The cooler was 95% clogged and had killed off the donor Disco.
Sounds like you have the "3 R's" - Rolling Recycled Relic. My daughter named ours, old Frankie was brought to life with parts from the dead ones....
And take some gator ade and a big hat this time of year.
Old Aug 31, 2011 | 05:31 PM
discomedic4's Avatar
That grill guard does look good. Kudos!
Old Aug 31, 2011 | 08:27 PM
Dodger's Avatar
Thanks, having a welder makes for fun projects. I need to paint it up now, and tidy up some loose ends. All in all I love the way it came out.
Old Sep 1, 2011 | 01:01 AM
yloDiscoII's Avatar
X2! Great job!
Walko327
Mar 8, 2013 10:23 AM
jrm123180
Aug 29, 2011 09:12 PM
GARovee
Nov 29, 2010 11:13 AM
Aj6543
Oct 5, 2008 05:48 PM
Aj6543
Off Topic
Oct 4, 2008 09:53 AM
