Junkyard '04 Transfer Case into '03
#21
I'm only re-using the front output assembly at this point, but I will definitely make sure to check and flush that. The pictures in the album show a little bit of shininess on a gear inside the main assembly.
Eventually I'll probably try to rebuild the junkyard case, probably some time this winter.
#22
Okay, I got everything put back together. Now the only issue I seem to be having is getting high range to engage. I don't have a problem getting low range to engage, but when I pull the lever back to put it in high, it won't engage and the warning keeps going off.
Any help here would be much appreciated.
Thanks.
Thanks.
#24
It's been empty for a couple months, it was the original transfer case to the car that was pulled out by the shop. I did refill it though.
I'm thinking I need to adjust the cable. With the gear all the way forward and the cotter pin pulled from the lever the cable is much farther back on the t-case than the lever is, so this is probably part of my problem at least. Do you know what size crows foot I need to loosen that cable up?
Or something screwy with the electrical connectors on the t-case.
#25
