Junkyard '04 Transfer Case into '03
Old Aug 15, 2016 | 03:56 PM
  #21
woodc85's Avatar
I'm only re-using the front output assembly at this point, but I will definitely make sure to check and flush that. The pictures in the album show a little bit of shininess on a gear inside the main assembly.
Eventually I'll probably try to rebuild the junkyard case, probably some time this winter.
Old Aug 25, 2016 | 08:19 PM
  #22
woodc85's Avatar
Okay, I got everything put back together. Now the only issue I seem to be having is getting high range to engage. I don't have a problem getting low range to engage, but when I pull the lever back to put it in high, it won't engage and the warning keeps going off.
Any help here would be much appreciated.
Thanks.
Old Aug 25, 2016 | 08:56 PM
  #23
chubbs878's Avatar
You did drain the fluids, right?
Old Aug 25, 2016 | 09:08 PM
  #24
woodc85's Avatar
It's been empty for a couple months, it was the original transfer case to the car that was pulled out by the shop. I did refill it though.
I'm thinking I need to adjust the cable. With the gear all the way forward and the cotter pin pulled from the lever the cable is much farther back on the t-case than the lever is, so this is probably part of my problem at least. Do you know what size crows foot I need to loosen that cable up?
Or something screwy with the electrical connectors on the t-case.
Old Aug 26, 2016 | 07:10 PM
  #25
woodc85's Avatar
Ok, so it engages high range just fine, but I guess the computer doesn't recognize that so it just beeps at me incessantly. The batter is completely dead (I keep having to jump it), do I need to somehow reset the computer or something?
CollieRover
Nov 18, 2015 06:29 PM
honda50r
May 26, 2011 10:57 AM
jacumja
Apr 27, 2011 02:38 PM
discoxd
Feb 27, 2009 08:30 PM
johnkbl
Sep 29, 2007 12:05 AM
