Just bought a 96 Disco (brakes, rotors)
Hey guys,
I just recently bought a 96 Disco having been won over from the Jeep family, and I could really use some help that would save me some money. The Discovery really needs new brake pads and rotors; I called the Land Rover dealership today and they said just for the front would be $700 dollars, I took it to my mechanic and he said he didn't even want to attempt it. Is it really that complicated of a fix, and if not could someone please help instruct me on how to do this myself or point me to a website that will explain how to do this.
Thanks
Mike in S.C.
Thanks
Mike in S.C.
Wow!!
As you have found the dealer is a huge rip off.
www.atlanticbritish.com has everything you could ever want for your truck.
If you dont want to do the work or cant then just take it to a brake shop.
It is really easy.
Have your wheel bearings repacked with fresh grease while they have the rotors off.
Your mechanic is scared because it is a Land Rover, doing brakes on your truck is not different than any other car.
It is really easy.
I have a 96 disco and it takes around 10 min per wheel to change the brake pads. all you have to do is remove the to cotter pins, remove the pin holding the pads, compress pistons put in new pads install retainer pins, cotter pins then you are done. Also you will need to bleed the brakes. start with right rear, left rear, right front, left front. always farthest from master cylinder
Walter
Walter
He needs new rotors too, and that takes more than 10 min.
You can get rotors and pads at NAPA and O'Reilly. I'm running Wagner from O'Reilly on my Disco at the moment.
You will need new hub seals and if you off-road you want to use RTC3511, only available from a rover parts house.
It's not a hard job at all, very simple and straight forward.
If I can find them I have photos of all the steps for a complete brake system overhaul, from MC to hubs.
rmally
04-22-2008 12:26 AM
