Just Bought a 99 LR Disco II
I love the feel driving it and honestly for the 1000 bucks i paid for the rig, its worth whatever repairs i need to make. It has three amigos, shop wants 100 bucks to run diagnostics for this... If anyone is near Boise ID and has a cpu Id forever appreciate help with diagnostics.
Idling in D at a stop sign earlier today and heard some tapping from under the middle console and back seat, shifted to N and it stopped, back to D no noise.... Maybe fluid is low? Tech at shop said one drop per second from front tranny pan plug means its full. So i need to check this. Oil in motor is excellent condition. Seems to run strong. But snow season is coming here and really need to figure out the three amigos issue before first snowfall. Heard a rumor it could ve as simple as a relay? This one does have the ACE unit. Any info or assistance would be greatly appreciated. Thanks all!
Buy a steel bumper off ebay - you will be glad you did. Three amigos is likely a worn wheel hub, you need a diagnostic tool to figure out which one. How many miles on the truck? Do a search on the forum on Delphi DS150 - it will read the codes and tell you which one. You should also read up on the Wabco Option B ABS modification.
They are a very addictive machine. I’m a poster child for how they suck you in. Good news is mine is a happy story.
So then, first things first:
- Do some googling or searching here on all the known issues of the Disco- you will have all of them at one point or another. They are all very well documented and cheap to fix once you can find used parts or suppliers
- Spend $100 on a Disco specific code reader (not generic). My first was an icarsoft. It will give you the code for specifically what it will take to fix the 3 amigos.
- Download the Rave service manual and get to bed time reading.
Specifically on the amigos it will will be one of 3 things: the hub as mentioned, a wheel speed sensor, or the shuttle valve. Look up “option b” for the shuttle valve and you will have the long term fix if that’s the issue (but you need the D2 code reader to know this).
Cosmetic stuff takes patience and perseverence and you and you can get whatever you need used for pennies. if you fall for them as I have, you’ll get good at fixing it, and learn how to keep it going for minimal $$$. They are really quite fun.
Quest4ADV (11-29-2018)
