Just bought my first land rover. But I need some help
Old Sep 13, 2008 | 11:28 AM
theworks001's Avatar
Default Just bought my first land rover. But I need some help
I just bought it yesterday its a 99 disco I belive its a 99i because they said if the hvac is manual its a (i) not a(ii).
there are 2 small leaks one is coming from some place near the oil filter this is the biggest one, but it stops once the disco cools down.
the other is comming from behind the engine I think its the differantial because the oil is a lot lighter than the engine oil it looks like a really light transparent green.
any ideas on both leaks???
thank you very much for your help
99 disco 97670 miles on it.
Old Sep 13, 2008 | 11:56 AM
snowdude's Avatar
Default RE: Just bought my first land rover. But I need some help
"really light transparent green"- anti freeze?
Old Sep 13, 2008 | 02:55 PM
Camdisco24's Avatar
I cant help you on the leaks but I will help you determine exactly which model you have:
The rear lights tell all.
Knowingthe modelwill help some people track down your problem better as well.
Old Sep 13, 2008 | 03:03 PM
Landzu's Avatar
So the Ugly one is the Disco II ,,,,,,,,,,,,
OK I just had to do it !
Old Sep 13, 2008 | 03:29 PM
Theworks-You need to take your truck back to the dealer and shove it up their ***. You have a coolant leak. That is the green stuff. If you stick your fingure in it and rub it it will be slimey.
The oil leak should not happen when the engine is running.That could be a leaking oil filter, could be anything.
Whatever you do DO NOT let the truck overheat because you WILL blow up the engine.
I am sure that the dealer didnt tell you this, but you MUST use premium gas in a Land Rover.
Michael M. Koch
Sep 10, 2012 07:29 PM
allroverthatwhip
Sep 8, 2012 05:33 PM
umwolverine
May 16, 2012 04:36 PM
JohnBloom
Mar 15, 2010 01:33 PM
j.dstasio
Nov 26, 2009 08:10 PM
