Just a few things for you guys
Old Aug 29, 2011 | 10:36 PM
bsnapp818's Avatar
Default Just a few things for you guys
My tail lights have some cracking in them, and are collecting water. This is causing a black film for show up and my lights are now very discolored.
First off, how do I remove them? Is it a simple unscrew them or are there things I need to worry about and keep an eye on.
Second, Can I drill some small holes in them(near the base) to allow them to drain? or do you think this will cause more problems.
Next question. When looking at the pictures of the G4 editions of the DII, I see a lot of front bumpers that look almost stock but have a winch bracket almost built into the center of the front bumper. Is there a company that makes these, or do I need to find a shop that will build one?
Thanks guys, so far the bill for parts needed to fix my little lady is around $1500.
Old Aug 29, 2011 | 11:42 PM
disc oh no's Avatar
My tail lights leaked and too. All you have to do is unscrew the screws (I think there's 4 on each side) and turn the bulbs out on the back side. Then just tip them back and forth until they're empty. I used a clear, two part epoxy that I got at walmart for like $3 or something like that and unless you are really close, you can't even tell. I mixed it up and then dabbed it across the crack with a toothpick. It ended up making about a 1/8 inch bead and sealed them up really well. They haven't leaked for about 6 months now. Just make sure you look over the entire surface of the lens including the seam on the edge where it is attached to the black plastic back of the light. If you don't get ALL the cracks they will leak again. Good Luck.
Old Aug 29, 2011 | 11:47 PM
disc oh no's Avatar
Oh, and also, I think that you may be better off SEALING the lenses back up instead of drilling drains in them because the connections don't take moisture too well and where I live the road salt in the winter would probably totally ruin them in a very short period of time. I also put a little dab of dielectric grease on each of the bulb bases and inside the sockets just to keep whatever left over moisture that may be in there off the connections. They did have a little condensation in them for a few days after putting them back on the truck but went away after that and never came back.
Old Aug 30, 2011 | 11:56 AM
yloDiscoII's Avatar
Originally Posted by bsnapp818
.........look almost stock but have a winch bracket almost built into the center of the front bumper. Is there a company that makes these, or do I need to find a shop that will build one?
You talking about this?
These are both discontinued and hard to find, check with The Rover Barn* - Home I just got a winch tray/A-bar like the one below from him last week, should be at my doorstep today.
Old Aug 30, 2011 | 12:53 PM
bsnapp818's Avatar
Have you ever heard of anyone having a winch receiver being made to look like the G4? It doesn't seem like it should be the difficult. possible it could be expensive tho..
The Super Gaz 1.6" lift on Atlantic British is only $499 for the next few days. Worth it? or should I just go Terrafirma?
BTW lights are cleaned out, and they actually look like tail lights instead of being all blacked out. Also decided to get rid of the soccer-mom mud flaps finally
Old Aug 30, 2011 | 01:06 PM
yloDiscoII's Avatar
I've seen a similar one made before for a DI. If you have access CAD and a good metal shop it wouldn't be that difficult or expensive. If you have a shop fab one up from scratch it will get $$$.
adventure95004
May 9, 2019 11:51 AM
calebbo
Oct 12, 2011 09:54 PM
Chrisinhouston
Feb 9, 2008 12:07 PM
MRDM1
Mar 16, 2007 07:03 PM
