Just finished my custom dash pod!
just put the finishing touches on my latest project. It started out as a store bought triple dash pod and I customized it to fit the void on the center dashboard. I thought it would look somewhat original in that location. I made a plug out of MDF, rounded over the edges with a router and cover it with fleece and resin. I modified the dash pod to void out the area where the mounting bolts went since I wasn't going to use them. The pod was then glued to the plug and then I bondo'd the corners for a seamless look. The finish is Duplicolor bed armor and lastly I dropped in some sport comp gauges I had laying around. So there you have it!
