Just got my first Land Rover
Old Oct 29, 2010 | 07:31 PM
halfassedastronaught's Avatar
5th Gear
Default Just got my first Land Rover
So just got my first land rover disco II (2003). Its awesome. Course having all the problems they have and thats fine by me cause thats what I like. gives me something to do. So can a senior member give me the inside on some good lift kits, what kind of axles does it have, splines etc etc. Any info would rock. I am a pretty good fabricator and want to make my own roof rack but would like to know what mounting kit would be used. For like arb type. still playing with it trying to figure out all the bells and whistles. Anyhow just wanted to post and say thanks for having a cool site for references. That rocks.
Old Oct 29, 2010 | 07:52 PM
ringerso's Avatar
Congrat's, and welcome to the forum!
Old Oct 29, 2010 | 09:16 PM
hilltoppersx's Avatar
first off did you check the vin is out of the bad oil pump range? did you rebuild your front drive shaft? did you complete the 60k service? welcome to the madness.
Old Oct 29, 2010 | 10:52 PM
JerrodSteph's Avatar
Welcome to the forum ! Check that vin for the oil pump issue, regardless install an oil pressure gauge to keep tabs.
Old Oct 30, 2010 | 01:19 PM
Rearden Steel's Avatar
Post some pics............
Old Oct 31, 2010 | 09:41 PM
5th Gear
thanks for the insight. now question that you had to have known was coming.... How do I check to see if my disco is in the bad oil pump batch? whats a good semi easy oil pressure gauge to install? like a column post type? also (lol) how do i post pics? i cant figure out how to look at others pics or do my profile cause it says i dont have permission to go to that area.
Old Oct 31, 2010 | 09:47 PM
buick215's Avatar
I believe that you have to be a member for an x amount of time or have an x amount of posts before you have all of the privileges, like viewing pictures etc.
Old Nov 1, 2010 | 12:20 AM
NiteTrain's Avatar
post your VIN # on here somebody can tell you if its in the bad range
get an account at photobucket.com or another pic hosting site to post pics
look at your front driveshaft, if the u-joints don't have greaseable zerk then rebuild it or take it to a drive shaft shop to be rebuild..should cost around $200
Old Nov 1, 2010 | 04:33 AM
BAD VIN's - 3A771801 - 3A808362...
marhain78
Jul 30, 2015 07:40 PM
Christina Jon Harrington
Jan 20, 2012 03:03 PM
timdunbar
Jul 31, 2010 05:05 PM
Fiz Rover
Mar 25, 2009 08:23 PM
armymp15
Nov 29, 2007 11:07 PM
