Just purchased 2001 LR series 2.
Old Jul 19, 2013 | 09:25 AM
terryga's Avatar
7th Gear
Default Just purchased 2001 LR series 2.
I would like to put new tires on stock rims. What is the largest tire I can go with? Hoping to put something on that has a more agressive look to it. Thanks
Old Jul 19, 2013 | 10:26 AM
Madlands's Avatar
If you are running 18in rims I would recommend going with a 265/60r18. That's around 30.5in. That is the size I have on my stock height 04, and they fit perfect with no rubbing at all. Ofcourse this is with newer springs that aren't worn out and droopy. So if yours are worn out then it might be a tighter fit.
And if you get a matching spare then it is the biggest you can fit without modifying or flipping the spare carrier.
Old Jul 19, 2013 | 10:59 AM
terryga's Avatar
7th Gear
Default I think rims are 16"
I will check when I get home, thanks. If they are 16" what size tire then?
Old Jul 19, 2013 | 11:21 AM
antichrist's Avatar
There's a faq on discoweb that lists tire sizess from stock to various lifts.
Just an fyi, the Land Rover Series II ended production in 1961. You have a Discovery II or Discovery Series II.
Old Jul 19, 2013 | 11:31 AM
Oh, these Newbees!!!!!!
What will you be using the truck for, Are you still on the original suspension?
Have you looked at my major service list, especially the front drive shaft issue?
Rferguson
Jul 23, 2013 08:49 AM
MichiganRover
Jan 10, 2013 04:23 PM
Maine Disco
Dec 2, 2007 12:12 AM
98DiscoC
Mar 12, 2007 05:09 PM
kelandra
Dec 22, 2006 10:43 AM
