Do I need o2 sensors?
Old Jul 19, 2013 | 12:03 AM
yaakov's Avatar
Default Do I need o2 sensors?
I'm getting p1171, p1174, p1412, and p1415 on a 2003 Discovery that's new to me, but that had the head gaskets replaced along with new plugs and wires about 10,000 miles ago or so when it was owned by my brother.
Do I need new o2 sensors up front? What should I check?
Old Jul 19, 2013 | 12:11 AM
yaakov's Avatar
Or do I need a new MAF sensor?
Old Jul 19, 2013 | 12:21 AM
yaakov's Avatar
or SAI?
I'm searching through the forum but don't know where to begin with it.
I should also note that the truck runs completely fine.
Old Jul 19, 2013 | 08:43 AM
Bob Loblaw's Avatar
Since the codes you have are for BOTH left/right and not just one side, I would not think that the O2 sensors are bad.
I don't have SAI in my truck, so I don't have a lot of experience there. If I recall correctly, SAI only runs for a little while right after the truck is started. (I think?)
Usually with codes like these, people suggest looking for vacuum leaks since that is a much cheaper route than replacing the MAF. Do you have an Ultra Gauge or something that would display your gas mileage? If you do have a vacuum leak your MPGs can drop noticeably. But the best way to find a vacuum leak is to listen for a hiss or do smoke test.
You'll probably want to get some opinions from people with more experience in the SAI area, but I've dealt with vacuum leaks and failing O2 sensors in my truck.
Old Jul 19, 2013 | 08:46 AM
yaakov's Avatar
I have a scangauge and get around 15 mpg. The SAI seems to run fine upon starting the truck. What's the best way to look for leaks?
Old Jul 19, 2013 | 11:42 AM
Bob Loblaw's Avatar
Here is a good example:
https://landroverforums.com/forum/di...s-cigar-54235/
Old Jul 19, 2013 | 11:44 AM
yaakov's Avatar
I had just found that! Headed out to get the tubing now.
Nay_Sayer
Feb 27, 2014 11:41 AM
Dean
Sep 24, 2013 04:44 PM
jsyonker
Sep 4, 2011 06:01 PM
2000 DII
Nov 1, 2010 01:01 PM
JRdisco1
Aug 9, 2005 03:33 PM
