just a quick what is this wire question
Old Nov 14, 2017 | 08:32 PM
driftology's Avatar
Default just a quick what is this wire question
i just repaired my abs module (did the external connection mod). i noticed a connector hanging near the module. I'm not sure it its part of the braking system. i see a clip on the frame where the other end should be. 3 amigos are gone tho!
Attached Thumbnails just a quick what is this wire question-20171114_105236.jpg   just a quick what is this wire question-20171114_105241.jpg
Old Nov 14, 2017 | 08:35 PM
aemnky606's Avatar
Wheel speed sensor connector.
Old Nov 14, 2017 | 08:38 PM
driftology's Avatar
that sounds important. where should the other end be? im shocked i dont have any codes with that not connected. is there only one wheel speed sensor connector?
Old Nov 14, 2017 | 08:47 PM
driftology's Avatar
i just went out to check and it looks like the speed sensor cable meets up with the other passenger side speed sensor cable and head through the firewall. however looked at the passenger side i did see the same unplugged connector. it was very dirty like it has not been plugged in to anything for a long time. i do know that the front wheel abs does work. i live in a snowy area and it gets put to the test alot. any other ideas?
Old Nov 14, 2017 | 08:58 PM
driftology's Avatar
a lot of searching shows that it is the abs connector. i wonder where my abs cables are going
Old Nov 14, 2017 | 09:09 PM
driftology's Avatar
so this is where my wheel speed sensors end up. just behind the air pump
Attached Thumbnails just a quick what is this wire question-20171114_220604.jpg
driftology's Avatar
maybe i should just leave it all alone since i dont have any warning lights lol
Old Nov 14, 2017 | 10:47 PM
landlover_1's Avatar
maybe ask Lisa.. she seems to know what is going on
Old Nov 14, 2017 | 11:15 PM
mln01's Avatar
I’ve read here several times that replacement wheel speed sensors are made to be wired directly to the SLABS box, bypassing the disconnected plugs in your pics.
Old Nov 15, 2017 | 06:20 AM
driftology's Avatar
ok that is good to know. i will just leave it all alone thanks for the help everyone
