just replaced spark plugs....now I'm having issues.
Old Jul 28, 2009 | 01:23 PM
crainface's Avatar
Thumbs down just replaced spark plugs....now I'm having issues.
I just replaced my spark plugs on my 2000 disco (used the bosch platinum +4's). I was having any issues prior to replacing them, but it was time. I didn't replace the plug wires. After I put them in I started to notice that the engine was having some problems. I'm getting some intermittent accelerations, sometimes it hangs up for a couple of seconds when I'm cruising. When I give it alot of gas it doesn't seem to happen, but I did the job yesterday, and it's definately getting worse. Is there any way i can narrow this down to a specific plug? They all went in pretty smooth.....is it possible that I damaged a plug wire....perhaps I didn't tighten one enough? Check engine light has not gone off.
Old Jul 28, 2009 | 01:32 PM
malmberg's Avatar
If I remember right you are not suppose to use the +4 without getting 8mm wires. I don't think that the stock wires send enough voltage. I would either order the magnecore 8mm or get some different plugs.
From lrrforums store
4418 Bosch Platinum +4 Spark Plugs
CODE: 4418
List price: $13.80
Our price : $7.50 Price: $0.00
You save: $6.30 (46%)
Add to cart
Fits: 99~04 Discovery II & 01~02 Range Rovers 4.0/4.6
For use with Magnecor Wires. We do not recommend these plugs with OEM Ignition Wires Sets.
Replaces factory Part # NLP100320 Size 5/8" OEM Plug Champion CC11PYPB4 (Double Platinum)
Old Jul 28, 2009 | 01:41 PM
crainface's Avatar
No!!! say it ain't so!......i don't know if my knuckles can take much more...
Old Jul 28, 2009 | 01:44 PM
Torancis_LR's Avatar
You might as well order the Magnecor wires and get the job done right.
Old Jul 28, 2009 | 01:50 PM
jycsalas's Avatar
and make sure you route them correctly
Old Jul 28, 2009 | 02:56 PM
lipadj46's Avatar
Cheapest place for magnecor 8mm is Apex Performance, $85+ shipping.
Old Jul 28, 2009 | 03:20 PM
jayv's Avatar
CODE: 4418
List price: $13.80
Add to cart
I am using the +4s with 7mm magnacore and my engine is running like new, not one hicup.
just FYI.
Old Jul 28, 2009 | 03:45 PM
When you pulled the plug wires from the old plugs, you may have pulled out some of the main wire from the connectors.
Old Jul 28, 2009 | 03:57 PM
crainface's Avatar
I just ordered the magnecor 8mm from apex performance.....also, if anyone wants to get 10% their next apexperformance.net order you can use the promo code "APEX-WINS-10".
Mike does that mean my wires are shot.......(if I pulled out some of the main wire)....is it ok to drive?
Old Jul 28, 2009 | 06:59 PM
jrkstore43's Avatar
Note that Apex Performance doesn't let you use that 10% discount on Magnecor wires...I tried that a few months ago. Unless they changed something...
