Just thinking
Old Jun 20, 2010 | 05:26 AM
Up N Over's Avatar
6th Gear
Default Just thinking
Can I use a steel expantion tank off a range rover if i change some out lets to replace my disco's one? this would give me a low level light then if i hook it up and to get away from the plastic crap.
Old Jun 20, 2010 | 08:40 AM
vandev's Avatar
Default hemm
not a bad idea...i would be curious to see how it comes out. There is a guy on the rangerover.net forums in AUS who made a alluminum thremostat that worked real well. he located the actual valve like in every other car and truck in the world where most are . It was working very well. I said it would be great to make a metal one that you could change the valve to one that matched the climate you where in. IE ,...hotter ...lower opening temputure... But i am not to bright as i own one..
Old Jun 21, 2010 | 02:38 AM
Up N Over's Avatar
6th Gear
Default yep
I'll let you know what happens, need to do some other jobs on it first
GARovee
Apr 13, 2015 10:11 PM
adigerol77
Apr 24, 2011 02:49 PM
Snafu / Disco Fries
Feb 27, 2011 05:53 PM
Disco Den
Jul 10, 2010 09:14 AM
rmally
Apr 22, 2008 12:26 AM
