K&N Filter?
RE: K&N Filter?
thankyouthankyou for the heads-up......I def not go down that path.
Just standard paper filters then?....
and I'll keep the oil filters in mind for next oil change.
much apprecieated....
ORIGINAL: Disco Mike
I have seen alot of Rover owners try K&N's, I did, and switched back after loosing 2 MAF sensors which are too sensitive to use with oil treated filters.
I swear by their oil filters, I have been using the 3001 oil filter for the last 3 years.
Mike
Mike
RE: K&N Filter?
I've been running a K&N in my '98 disco for a few months now with out a problem (I assume a MAF failure would be fairly obvious, maybe I am wrong). I will definatly keep more of an eye on things to see if there are any problems.
Next oil change is when I am coming up on time to clean and re-oil the filter, so maybe I will just swap it out with a paper one instead.
on
RE: K&N Filter?
ORIGINAL: LordOphidian
Mike
