K&N Filter?
Old Aug 1, 2006 | 11:36 AM
2tall4u's Avatar
Default K&N Filter?
Hey again....
Looking at putting a K&N filter in my 97 Disco....just wanted to make sure I wasn't going to screw anything up....
No problem?
Old Aug 1, 2006 | 01:26 PM
Default RE: K&N Filter?
I have seen alot of Rover owners try K&N's, I did, and switched back after loosing 2 MAF sensors which are too sensitive to use with oil treated filters.
I swear by their oil filters, I have been using the 3001 oil filter for the last 3 years.
Mike
Old Aug 1, 2006 | 06:40 PM
2tall4u's Avatar
thankyouthankyou for the heads-up......I def not go down that path.
Just standard paper filters then?....
and I'll keep the oil filters in mind for next oil change.
much apprecieated....
ORIGINAL: Disco Mike
Mike
Old Aug 1, 2006 | 10:09 PM
2003Disco2's Avatar
wait im confused, so k and n oil filters the 3001 are good to use correct? because I just put one on my d2 lol, just wanted to make sure you were saying good things about hte oil filter, and bad about the air....thanks
Old Aug 1, 2006 | 10:25 PM
Your are right, they make a super oil filter.
They make a good air filter, they are just not real compatiable with Rovers, and at $140 in parts for a D2 MAF and nearlt $600 for a D1, you work the numbers.
Mike
Old Aug 1, 2006 | 10:29 PM
2003Disco2's Avatar
so i shouldnt return my oil filter? the oil filter will not mess up anything in my d2???? i thought you were saying hte oil filters mess up the maf
Old Aug 1, 2006 | 11:49 PM
2tall4u's Avatar
K&N AIR filters are "oil treated".....and (from what disco mike is saying) can mess up your MAF...
K&N OIL filters are excellent.
Thanks for the help DiscoMike.
Old Aug 2, 2006 | 11:02 AM
ORIGINAL: 2tall4u
I must not have said that right, thanks for making it clearer.
Mike
Old Aug 3, 2006 | 09:28 PM
LordOphidian's Avatar
I've been running a K&N in my '98 disco for a few months now with out a problem (I assume a MAF failure would be fairly obvious, maybe I am wrong). I will definatly keep more of an eye on things to see if there are any problems.
Next oil change is when I am coming up on time to clean and re-oil the filter, so maybe I will just swap it out with a paper one instead.
Old Aug 3, 2006 | 11:32 PM
ORIGINAL: LordOphidian
For what it could cost you to replace a MAF for your truck, you can buy lots of good quality air filters and gas. There is hardly any saving when using a K&N except at highway speeds and then it is very small, your engine oil gets lots dirty much quicker, it is not worth the risk.
Mike
Billj214
Aug 11, 2023 05:43 AM
nottin
Dec 25, 2008 08:48 PM
AndyTeez
Sep 2, 2007 10:42 AM
animalcracker
Sep 24, 2005 06:32 PM
fuel
Dec 13, 2004 04:49 PM
