Key Cylinder is TOUGH
I've had to replace some pretty nasty locks that the customer just kept dumping Graphite into... The end result was a lock out/drill along with a new lock.
On a LR ignition switch Tri-Flow would be my #1 choice, but since it can be kinda hard to find depending on your location any lube used lightly on just the key (then rake it in out) should do the trick.
Another quirk is that my steering wheel needs to be precisely pointed straight ahead, and not locked by the mechanical steering anti-theft, for the ignition key to easily rotate without muscle-power.
When it is mechanically locked, I have to manually move the steering wheel into the straight-ahead driving position such that there is no tension on the steering wheel form the mechanical anti-theft lock mechanism. Then the ignition switch freely turns with the key.
If it happens, someone take a pic for me, please! Dump some graphite on a piece of paper and show me.
*Where do you buy graphite dust? In the car key section of big box stores.
People say the darnedest things. I'd love to see a glob of graphite "bind" anything. It ain't glue, y'all!
Okay here is the basics with "graphite" it was used back in the day when there wasn't Tri-Flow, WD40, or any other lubricants. Back then locks got old & worn out & graphite was used to fill the gaps of the old locks and to lube it....
It is a "snake oil" for locks of today and it does more harm than good. Those auto store chains also sell fake hood scoops which do absolutely nothing....
