Key and Fob Upgrade Pictures
Old 06-09-2013, 10:58 AM
silar's Avatar
Originally Posted by lostl13
I would like to buy a used Discovery FOB circuit board if anyone has one. I'm repairing mine and the momentary buttons are trash so those are what is needed. I Tried Radio Shack and the buttons they had worked fine but would not fit in the case correctly... Thanks!
Attachment 16597
You can also get them on ebay...
land rover key micro | eBay
  #82
Old 06-09-2013, 11:46 AM
lostl13's Avatar
Thank you! Making my purchase now!
OK, $6.28 USD straight from the U.K. As soon as they arrive I will post a write up with pics if anyone would like to try the same thing.
  #83
Old 06-18-2013, 02:25 PM
eitydeuce's Avatar
Wheeler, how does that fob close up? the other one has screws to secure both half's together. The one you mentioned does not have anything keeping it together.
  #84
Old 06-18-2013, 03:12 PM
wynhd's Avatar
I have one I ordered from ebay, its not being used, its the same flip style. If anyone wants it, send me a PM.
  #85
Old 06-25-2013, 10:06 PM
pinkytoe69's Avatar
As posted earlier, I ordered this:
Uncut Blank 2 Buttons Flip Folding Remote Fob Key Shell Case for Land Rover | eBay
Some key duplication research revealed that the normal way to start is to line the keys up by the shoulders. Obviously this doesnt work in our case...they have to line them up by the tip.
Armed with that knowlege, I tried to take it to an old school key and lock shop, but his power was out due to storms. I then went to an ACE hardware where the key cutter was a high school looking kid. Against my better judgment, I explained the deal with the shoulders and let him give it a try.
He got one side cut perfectly. However, the big nub on the end for the swivel post wouldnt allow the key to fit into the machine the reverse way. I now have to find someplace with a different kind of machine.
Wont be sure until I can get the other side cut, but it seems if you give the cutter the tip alignment info it'll come out ok.
  #86
Old 06-26-2013, 06:51 AM
drowssap's Avatar
cant you just take the blade out of the case so it can be cut?
  #87
Old 06-26-2013, 10:40 AM
pinkytoe69's Avatar
I think so, but I would have to punch the little dowel out. Worried about breaking it.
  #88
Old 06-28-2013, 04:19 PM
jbarr89's Avatar
i pushed it out using a tie clip/pin; worked fine and didnt mess anything up
  #89
Old 07-01-2013, 06:06 PM
pinkytoe69's Avatar
Ok, success...kinda.
Pushed out the dowel (that was embarrassingly simple) and got the other side cut.
Went to a Hardware Hank. The key cutter noticed that the first machine he tried was not making a fine enough cut. He used the other machine they had and finished it up. The finer cut is very evident.
So, the key will turn when inserted one way, but not the other. Im not sure if the round cut or fine cut is the one that is working. Will post pics in a bit.
  #90
Old 07-03-2013, 07:43 PM
pinkytoe69's Avatar
Heres the pic.
You can see one side has fine little steps in it.
The key only turns with that fine side down.
Does this mean the rounder side is the one that works?
Quick Reply: Key and Fob Upgrade Pictures
