Key Prgramming
Old Aug 27, 2007 | 05:32 PM
certifiedimports's Avatar
Default Key Prgramming
I have a master key with remote and want to add another. I have purchased a brand new key wtih remote from my local dealer. Is there a way that i can program that key myself, or is going to the dealer the only option? Thanks in advance for any help.
Old Aug 27, 2007 | 06:37 PM
DAMU916's Avatar
Default RE: Key Prgramming
YEAH U CAN PROGRAM IT YOUR SELF VERY EASY
1. ENSURE THE VEHICLE IS UNLOCKED AND DRIVER AND FRONT PASSANGER DOORS ARE CLOSED
2. INSTALL A KEY/REMOTE HANDSET IN THE INGITION SWITCH, AND THEN TURN THE IGNITION SWITCH TO POSITION I AND BACK TO POSTION 0 IN LESS THAN 5 SECONDS TO PUT THE BCU INTO THE INITIALIZATION MODE.
3. REMOVE THE KEY/REMOTE HANDSET FROM IGNITION SWITCH
4. PRESS AND HOLD THE UNLOCK BUTTON DOWN (BASICALLLY WHEN IT STARTS BLINKING) @ THE SAME TIME PRESS THE LOCK BUTTON THREE TIMES .
5.THEN LET BOTH BUTTON GO
MOMENTERLY IT SHOULD START BLINKING SLOWLY
REPEAT STEP 4 AND 5 WITH ALL OTHER REMOTE HANDSETS WITHIN 30 SECONDS
THAT WILL BE IT PROGRAM KEY WITHIN MINUTES A 140DOLLAR SERVICE
Old Aug 27, 2007 | 06:46 PM
If it is a D2, you must take it to the dealer only.
Old Aug 30, 2007 | 11:31 AM
loic's Avatar
ORIGINAL: Disco Mike
what is the cost on this ? and the extra key how much does it cost ?
when I bought the truck (used) they gave me only 1 key.... I just hope I'm not going to loose it.....
Old Aug 30, 2007 | 12:02 PM
You can get a standard key made, without a remote pretty cheaply.
If you are patient, you can find the proper two button remote on e-bay for around $50, closer to a $100 from the dealer. Then you have to get them programed, about $100 from a dealer a little less from a smaller Rover shop if they have the proper scanner to do the job with.
Discolife
Nov 25, 2011 11:38 AM
freelander2002
Oct 27, 2009 05:07 PM
pilsner
Apr 7, 2008 03:24 PM
plastique999
Jan 22, 2008 01:34 AM
Jay
Apr 27, 2005 03:49 PM
