Key will not turn in ingnition
Old May 21, 2016 | 10:48 AM
Nick Johnson's Avatar
8th Gear
Well the OP works long days. Today is my last day before it is towed. I am out here now working on it. I believe I see the two large rivets or blank screw or whatever but I'm not sure about the ignition connection you are referring to. Is it the one on the left side of the ignition? If so, I think I see the two screws and can pull them out without taking the rivet screws out. Am I looking at the wrong one?
Old May 21, 2016 | 12:30 PM
8th Gear
So guess what... It worked! I probably chiseled too much because I was thinking I was going to have to get some force to get those screws to turn but once I put the screwdriver in and tapped it a bit, they were super easy. Not sure what it was, but after I pulled the ignition out the key still would not turn. I pulled the back connector out and the key turned with no problems. Put the connector back in and still no problems. Thanks abran for the perfect guide. Now on to the A/C and driveshaft!
Old May 21, 2016 | 01:04 PM
DiscoBuckeye's Avatar
Awesome news!
Old May 21, 2016 | 10:17 PM
abran's Avatar
Congrats
Old May 22, 2016 | 01:23 AM
cappedup's Avatar
Yay. You essentially stole your own car. Grats.
Old Nov 21, 2016 | 04:02 PM
jastutte's Avatar
this thread was exactly what i needed. followed the six easy steps and was back on the road.
Old Nov 21, 2016 | 04:08 PM
LR03NJ's Avatar
Originally Posted by NVDiscovery
When I had a bad/worn ignition lock I had to slightly pull out the key as the key was, in essence, over inserted into the lock. Changing the ignition lock and cutting some new keys fixed the issue.
HAHAHA! My ignition is the same way! Until now. VALET proof. Anyway, I like it like that since nobody knows how it works except me. On the other hand, I hope that is the same problem as the poster.
OOOPS! did not read above. SOLVED!
molly
Jun 12, 2020 01:34 PM
cavdiver2
Dec 8, 2014 06:02 PM
cavdiver2
Dec 7, 2014 06:27 PM
bardel
Jul 28, 2010 10:50 PM
