KEY WONT TURN?
RE: KEY WONT TURN?
Seems stupid, but are you using the right key for the right trk? Did you try turning the key over? Sometimes double sided keys wear out on one side and then that side wont work.
Also try slamming the gear shifter into park, if it is not in park all the way it wont let you turn the key.
